Proud new owner
Re: Proud new owner
Post by turbo-tom » Mon Sep 09, 2013 9:29 pm
Steel diff ;)
Re: Proud new owner
Post by Jordi » Mon Sep 09, 2013 9:31 pm
b3n16 wrote:Is there a common upgrade or mod for this?.
I have no idea. All i know about Vitaras is what i have read on other peoples posts and build threads. Quickest way is probably to bang up another thread in the Vitara specific tech section.
b3n16
Re: Proud new owner
Post by b3n16 » Mon Sep 09, 2013 9:35 pm
turbo-tom wrote:Steel diff ;)
Ahhh. I suppose that's one way around it :D.
Re: Proud new owner
Post by Anton » Mon Sep 09, 2013 9:36 pm
Yes, steel diffs from Grand Vitaras (diesels too, I *think*) are a common upgrade, but also I believe you can brace the ally ones so they don't break so easily. It's the diff casing that breaks, then the gears don't mesh right and chew through each other.
A friend of mine broke about 6 of them before selling his vit. It's mostly down to shock loading the front drivetrain, or so I'm told - the steel diff casing (or a braced diff casing) stands up to much more abuse.
If you're careful about lifting off as you put a wheel back down, you may be ok. Another friend had a vit for a couple of years and, despite driving like he stole it, never broke a diff - because he was careful to lift off at times when he knew he was in danger of killing the front diff.
b3n16
Re: Proud new owner
Post by b3n16 » Mon Sep 09, 2013 9:37 pm
Will do mate. Thank you for the sound advice. I think I shall take the first comment in for the time being and just drive it :doublethumbs:
b3n16
Re: Proud new owner
Post by b3n16 » Mon Sep 09, 2013 9:39 pm
Anton wrote:Yes, steel diffs from Grand Vitaras (diesels too, I *think*) are a common upgrade, but also I believe you can brace the ally ones so they don't break so easily. It's the diff casing that breaks, then the gears don't mesh right and chew through each other.
Again this is awesome info. Thanks for all of it.
Re: Proud new owner
Post by Jordi » Mon Sep 09, 2013 9:41 pm
As with most off roaders mods tend to be done for two reasons
1) you broke something and don't want to break it again
2) you tried to get somewhere and got stuck and don't intend getting stuck there again
Re: Proud new owner
Post by turbo-tom » Mon Sep 09, 2013 9:45 pm
If I get stuck I will try again but with more power and repeat until I get through failing thatf if I can I try going the otherway that normally solves it. :) im not saying power is everything but its closest until you get lockers.
b3n16
Re: Proud new owner
Post by b3n16 » Mon Sep 09, 2013 9:50 pm
turbo-tom wrote:If I get stuck I will try again but with more power and repeat until I get through failing thatf if I can I try going the otherway that normally solves it. :) im not saying power is everything but its closest until you get lockers.
Lol. My technique seems to be try the hardest thing, then when really stuck get out and say.... Nope l that's stuck
Re: Proud new owner
Post by donkeychomp » Mon Sep 09, 2013 10:22 pm
Yep, most front diffs are alloy and very fragile, best get a diff guard made up, easy and cheap to do too!
