will they fit ???
- donkeychomp
Re: will they fit ???
Well Ive already chopped the crossmember ends and done the seam so hopefully they should go on alright! I've got to do my bumpstops at some point anyway so I'd rather do them after ive fiddled with the suspensionScottieJ wrote:I used to run 31x11.50 tyres on my Sj with just 2" lift springs and 2" dropped bumpstops, all I had to do was cut the front crossmember ends off and fold the bulkhead seam over, the narrower 410 axles helped a bit with clearance though.
well i have opted for soem 30 9.50 15s as i got a fulll set new for just under £100 lol bargain. the arches have rusted away and now have been welded at the highest point that i could. the front cross member will be chopped off shortly and then i will do a 2 inch body if it needs it . speed is not important really as i only drive to work and back so no rush at 8 in the morning ill keep you all posted
I wouldn't bother with a body lift, doubt it will be needed.
Even on 31s with virtual lift to the bottom of the groove had plenty of clearance. 30s will be fine, just fold the bulkhead seam over.
good to know thanks people
