Showoff.timwilks13 wrote:400th post woop.
Tims SJ410 Build Project
Re: Tims SJ410 Build Project
I can barely remember when I was at 400
- timwilks13
- SCUK Website Padawan
I think it was about 3013 posts ago perhaps?twiss wrote:I can barely remember when I was at 400
Erm..... You need to spend more time on here.timwilks13 wrote:400th post woop.
- timwilks13
As request Jordi more posts! Door is repaired, by no means perfect but should give me a year or so. Painting continues, and arches are being done as the paint dries!
- IMG_20131112_213811.jpg (2.23 MiB) Viewed 4455 times
- IMG_20131112_211957.jpg (2.6 MiB) Viewed 4455 times
- IMG_20131112_211927.jpg (3.3 MiB) Viewed 4455 times
- donkeychomp
Have fun getting the wall clean!
Hope the door lasts longer than that...
Super job on the door, Tim!
- timwilks13
I have only patched up the big hole in the bottom, its starting to rust up inside the door pretty badly, so that will come through sooner than later i imagine.donkeychomp wrote:Hope the door lasts longer than that...
timwilks13 wrote:I have only patched up the big hole in the bottom, its starting to rust up inside the door pretty badly, so that will come through sooner than later i imagine.donkeychomp wrote:Hope the door lasts longer than that...
Take the door card off, rub down the rust, give it a good coating with red oxide. You won't have to worry about it for years then.
