Muddy good weekend - 25-26th April 2015 (Formerly Billing)
Kermes-vermilio
Re: Muddy good weekend - 25-26th April 2015 (Formerly Billin
Post by Kermes-vermilio » Wed Apr 22, 2015 10:28 am
I think I'm ready! Didn't give the vit any more coats of paint so still a little patchy but its all good!
Expecting some nice weather for it :-)
What time are people planning on getting there/setting off to go there?
Post by dan_2k_uk » Wed Apr 22, 2015 3:00 pm
Between midday Sunday and last night I've had the transfer and gear boxes out and back in, inspected clutch and cleaned linkage, replaced wheel bearings on 3 corners and adjusted the 4th including removing shafts cleaning swivels and greasing CVs, transfer box now in RW cradle, stripped cleaned and tried to improve x-eng, went to remove a 2nd rear prop which turned out to be just as bad as my current one.
Tonight I need to do gearbox and diff oils, try to make rear prop slide fit tighter?!?!.......
Then she should be good. :D
Post by ScottieJ » Wed Apr 22, 2015 3:14 pm
I'm in the workshop tonight checking it over.
Do my usual...check fluids, give stuff a wobble to check for play, jack each wheel up to see if any bearings are noisy or have play.....
Might actually clean it?
Depending on the weather forcast might fit the half doors.
Kermes-vermilio
Post by Kermes-vermilio » Wed Apr 22, 2015 3:57 pm
:popcorn: That's some good effort!
I tell a lie, I did actually adjust my handbrake because it didn't actually stop me from moving ha.
My gearbox is so rattly now, I am expecting this weekend to be the death of it :pissed:
Post by donkeychomp » Wed Apr 22, 2015 9:18 pm
According to every weather thing I've checked it'll be chucking it down. Doors staying on!
Post by Anton » Wed Apr 22, 2015 9:28 pm
donkeychomp wrote:According to every weather thing I've checked it'll be chucking it down. Doors staying on!
I want clear skies and sunshine over billing. Think Bahamas. Then I want torrential rain and maybe even a hint of severe flooding in Barton Le Clay. Think Noah.
:lol:
Anyone living in/near Milton Keynes/Barton Le Clay, I am kidding, ok?
Sort of... :hahaha:
Post by Jordi » Wed Apr 22, 2015 9:46 pm
At the moment it's half doors all the way!
Post by dan_2k_uk » Wed Apr 22, 2015 10:00 pm
Forecast started picking up this evening.
Post by dan_2k_uk » Thu Apr 23, 2015 8:00 am
Probably leave Swindon around 3-4 depending what time Scottie makes it to mine. Anyone who wants to join the convoy from Swindon PM me for my address.
Post by Anton » Thu Apr 23, 2015 8:52 am
dan_2k_uk wrote:Between midday Sunday and last night I've had the transfer and gear boxes out and back in, inspected clutch and cleaned linkage, replaced wheel bearings on 3 corners and adjusted the 4th including removing shafts cleaning swivels and greasing CVs, transfer box now in RW cradle, stripped cleaned and tried to improve x-eng, went to remove a 2nd rear prop which turned out to be just as bad as my current one.
So far, I think you're winning the "did most stuff to prepare" trophy...
