Fwb's SJ410 Build
Re: Fwb's SJ410 Build
Post by ScottieJ » Fri Oct 10, 2014 7:25 pm
dan_2k_uk wrote: Will allow you to squeeze 31s on at standard height.
Or bigger :brows:
Fwb2700
Post by Fwb2700 » Fri Oct 10, 2014 7:31 pm
Yea I read your article the other day defiantly going to do it. Will keep the centre of gravity low and hopefully less Likeky to roll.
I just need to find some front leafs that are not inverted
1984 Suzuki SJ410q Winch Truck (Work in Progress)
kiwizook
Post by kiwizook » Fri Oct 10, 2014 8:07 pm
contact mudbits in tauranga, he might have some front springs, no one knows how much he'll charge you for it though!
http://www.mudbits.co.nz/
Fwb2700
Post by Fwb2700 » Fri Oct 10, 2014 8:13 pm
I personally wouldn't use them anymore too bloody expensive had a quite for a full suspension lift kit $1200 I know the old owners dog he's in the local 4x4 club. I might need to ask around
kiwizook
Post by kiwizook » Fri Oct 10, 2014 11:36 pm
yea, he gives good service, but is bloody expensive. there was also a breaker here in masterton, but he has left his missus, and I think he left all his parts etc with her and the property. I'll see if I can get hold of him to see if he has some springs for you
Post by Anton » Sat Oct 11, 2014 12:06 am
Loving the total strip down and rebuild approach you're going for, and I would go virtual lift if I was building another SJ. Spring over axle is the route I went, and it ended up too high for my liking.
Although it's nice being really really high on the road, it a little bit less stable off road. But still surprised at how stable the old gal is!
Fwb2700
Post by Fwb2700 » Sat Oct 11, 2014 12:55 am
kiwizook wrote:yea, he gives good service, but is bloody expensive. there was also a breaker here in masterton, but he has left his missus, and I think he left all his parts etc with her and the property. I'll see if I can get hold of him to see if he has some springs for you
That would be great no one over here has anything to do with Zuk parts and I do regular trips over their as I have a fair but of family in masterton.
I am also looking for a complete front axle hub to hub for spares and rear disk conversion
Fwb2700
Post by Fwb2700 » Sat Oct 11, 2014 10:56 am
Post by dan_2k_uk » Sat Oct 11, 2014 11:19 am
Or bigger :brows:
Yeah I just meant if you follow the guide and go round the bottom of the lip. :thumbup:
Fwb2700
Post by Fwb2700 » Sun Oct 12, 2014 11:47 pm
Well just started the dreaded part of the build. Trying to fix what little bit of the body that remains. It has had so many bad repair jobs in the past. Some ass has just riveted new steel over rust. Or put 2" thick layer of bog/filler.
Time to get cutting I think. Prob should go but some steel and some gas for welder.
Any ideas on a custom dash? Want to remove the stock steel one and maybe make a wooden 1.
