A run of bad luck
Re: A run of bad luck
Post by Jordi » Sun Nov 09, 2014 8:14 pm
Yeah, should sort the problem.
Just run spacers on the front to match the width.
His kit doesn't have oil seals either.
Post by ScottieJ » Sun Nov 09, 2014 10:34 pm
I've been running it without adding a seal for around 18months now, still on the same bearings that were fitted when I bought the axles off Tim pink, seams like a bit of gear oil actually helps them last.
Ladaman
Post by Ladaman » Sun Nov 09, 2014 10:41 pm
Are you using the Rob Storr full float rear set up Scottie?
I've just PM'd Mike H and he is, so it looks like that might be the way to go.
Post by ScottieJ » Sun Nov 09, 2014 10:54 pm
Yes I've been running it for 18months or so now, possibly longer?
Ladaman
Post by Ladaman » Sun Nov 09, 2014 11:17 pm
Just had a look through your build thread, and found it.
P53, so I can find it again, and it was 5th July 13 when you put pics up.
I think a call to Mr S in needed. ;)
Post by Anton » Mon Nov 10, 2014 12:52 am
Jealous!
