gratton
Post
by gratton » Fri May 22, 2015 11:12 am
gratton
Post
by gratton » Fri May 22, 2015 11:24 am
pics of the ball joints
- FB_IMG_1432290098730.jpg (52.03 KiB) Viewed 6209 times
- FB_IMG_1432290103525.jpg (55.66 KiB) Viewed 6209 times
- The Boss
Post
by ScottieJ » Fri May 22, 2015 11:31 am
The ball joints look fine, could probably do with some new felts but those aren't even that important anyway.
Personally I would jack each side up, check for any play, give them a spin to see if they are noisy and just replace what needs changing, it's not hard to rebuild an Sj axle and you can easily just service one side at a time.
gratton
Post
by gratton » Fri May 22, 2015 11:49 am
Thanks nice one will get on it this weekend
- The Boss
Post
by ScottieJ » Fri May 22, 2015 11:59 am
This thread tells you how to check and set up the wheel and kingpin bearings, if there's a bit of play in the kingpins you might be able to just remove some shims if there's any left, keep any that you take out for when you fit new kingpin bearings.
http://forum.suzukiclubuk.co.uk/vi ... =12&t=3182
Also you can download a service manual that shows all of the above a how to change bearings here
http://www.4x4.in.th/manual_sj413
There's also a guide in the "how to guides" section of the website ^^^
gratton
Post
by gratton » Fri May 22, 2015 12:20 pm
Nice one thanks
