Engine serial number
Re: Engine serial number
Post by dan_2k_uk » Wed Feb 01, 2012 4:14 pm
Keep an eye on this thread then
http://www.suzukiclubuk.co.uk/phpBB3/ph ... =13&t=4060" onclick="window.open(this.href);return false;
Dan :thumbup:
Post by Anton » Wed Feb 01, 2012 11:40 pm
dan_2k_uk wrote:Keep an eye on this thread then
Dan :thumbup:
Very interesting!
Not sure which way to go. I know I'll change my mind 20 times, so at the mo I'm just gathering info in case I do decide to go for a 1.5.
Good chance I'll just go for a G13B, though. Or just port/polish what I have, add a 2" exhaust, and throttlebodies etc. I can always swap to a 16v later, the headers should still fit.
Plenty to be getting on with anyway. Get new V5. Fill in the bit about engine changes, and get another new V5. Body swap. Get a new V5 again. Design, build and fit 3-bar front and rear. Calc weights and spring rates etc based on the vehicle's new weight. Recondition and fit freewheeling hubs. Finish making, and then fit, rear disk brake conversion.
Plenty to do! ;)
Post by twiss » Fri Feb 03, 2012 11:21 am
Anton wrote: Good chance I'll just go for a G13B, though. Or just port/polish what I have, add a 2" exhaust, and throttlebodies etc. I can always swap to a 16v later, the headers should still fit.
I'm assuming you mean 1600 rather than 16v? If you go from 8v to 16v your manifolds/headers wont fit
Post by ScottieJ » Fri Feb 03, 2012 11:44 am
Yup Twiss is correct, 8V & 16V have different bolt positions for the inlet and outlets.
Post by twiss » Fri Feb 03, 2012 11:46 am
Speaking of which.... I don't have an exhaust manifold for my new engine! Ooops!
Post by ScottieJ » Fri Feb 03, 2012 11:58 am
rays? or I know there are a few 16v's in the crappy near me so could go pull you one on sat morning if needed?
Post by Anton » Fri Feb 03, 2012 12:14 pm
Didn't know that. No, I meant swapping the G13BA for a G13B.
Oh, it's all so complicated! :S
If I go with ITB's from a bike, I'll have to make an intake manifold. When I do, I'll just have to make sure it's either got the right bolt holes for both heads, or easily modded to fit.
Post by twiss » Fri Feb 03, 2012 12:19 pm
Yeah the B and the BA manifolds are interchangeable as they are both 8v. I think the heads are interchangeable as well but may be wrong on that one...
Post by Anton » Fri Feb 03, 2012 12:31 pm
Do you mean the A and BA?
I thought the B was 16v?
Post by ScottieJ » Fri Feb 03, 2012 12:43 pm
The G13B is the 16v dohc swift gti lump, the inlet and exhaust off a G13a or ba will not for this head.
