Samurai SJ413 clutch swap UPDATED
Re: Samurai SJ413 clutch swap UPDATED
Post by Jordi » Sun Aug 17, 2014 5:30 pm
Can do it with the gearbox in, just gotta slide it back.
Post by twiss » Mon Aug 18, 2014 9:40 am
Its an easy side of the road job :)
timwilks13
SCUK Website Padawan
Post by timwilks13 » Wed Aug 20, 2014 2:25 pm
Just to clarify Jordi, which way round does the clutch go in? I can never remember and wouldnt want the ridicule of getting it wrong....
Post by twiss » Wed Aug 20, 2014 2:35 pm
The flatter side of the clutch faces the flywheel... as it doesn't really fit the other way around ;)
Akseli
Post by Akseli » Wed Oct 08, 2014 6:23 pm
Ok, done the swap, i had to remove a bracket on the exhaustpipe and after that the gearbox went enough backwards so that i managed to swap the clutch disc and reinstall the clutch pakage back with a aligment tool.
If i`d been slightly wiser i`d would have drained the gearbox beforehand, the slipyoke fell off as i was removing the gearbox and started to drip oil on me :pissed:
Snow is usually white and cold
Post by twiss » Wed Oct 08, 2014 6:54 pm
hahah thats a common occurence... there always have to be some oil involved ;)
Trick is to tilt it forwards so it can't leak out!
Akseli
Post by Akseli » Thu Oct 09, 2014 1:47 pm
twiss wrote:Trick is to tilt it forwards so it can't leak out!
I agree you on that, had the cars front tires on blocks and the rear tires on ground :twisted:
Never the less, a valuable lesson was learned :mrgreen:
Post by twiss » Thu Oct 09, 2014 3:36 pm
When me and andyrew took a vitara engine out, I ended up covered in coolant and he ended up covered in transmission fluid!
The coolant sounds like the preferred option but he didn't have to drive 100+ miles home covered in it ;)
(with an engine and gearbox wobbling about in the back i might add)
