Tramps Truck,
Re: Tramps Truck,
Post by Tramp » Wed Nov 11, 2015 9:29 am
Sounds like a plan, it would be great to make it to an event and meet all the faces from this forum, not having a road worthy truck has put me off until now, but I'll have no excuse now!
zook123
Re: Tramps Truck,
Post by zook123 » Wed Nov 11, 2015 12:50 pm
Keep up the good work!!!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Re: Tramps Truck,
Post by Tramp » Thu Nov 12, 2015 2:45 pm
More patching,
In the passenger side inner sill,
Passenger side rear wheel arch
& the patch should I put a drain hole in here? Or is it ok?
And I painted the inside of the sill, chucked some filler on the flare behind the rear wheel and found another hole......
Behind the passenger seat, that's the chassis I can see under there, is this something I can repair with the body in situ on the chassis or will I need to separate them?
Re: Tramps Truck,
Post by Tramp » Sat Nov 14, 2015 6:53 pm
So carrying on from last time,
Heres the inside of the sill, painted and ready for the new box section,
So today box section prepared and capped
Then the outer edge welded in
I've still got the inside to weld but it's on!
Then whilst I was under I was looking at that big rust hole,
Any idea how to tackle it?
Re: Tramps Truck,
Post by Tramp » Thu Nov 26, 2015 4:51 pm
So another day,
The sill fully welded in, the rear wheel arch (passenger side) completely patched up - it doesn't look much but it took me most of the day,
So what's left?
Flat the filler on the rear passenger 'rot' trap and paint,
I have to refit the bumper/tow bar
Buy and make some brackets to hang my sill plastics on (and paint)
Address the hole in the floor behind the seats
Remove the rear half shaft, paint the drum backing plate, and change the bearing
Fit new copper brake lines cylinder and components
Drive,
Not much left now!
Re: Tramps Truck,
Post by ROBBIE » Fri Nov 27, 2015 11:50 am
Nice work Tramp, the box takes me back to when I did mine and will probably out live the truck :lol:
Re: Tramps Truck,
Post by Anton » Fri Nov 27, 2015 3:43 pm
We like stuff that's built to last, we does. :salute:
Re: Tramps Truck,
Post by ScottieJ » Fri Nov 27, 2015 7:08 pm
Looking good! Bet you can't wait t have it back on the road.
Re: Tramps Truck,
Post by Tramp » Sat Nov 28, 2015 6:08 pm
Yeah I seriously can't wait to be blasting about in it again! Looking back at this thread makes me realise I've spent nearly a year on it now, Good progress considering it took 5/6 years to work myself up to starting it!
Anyway I had a little time on it today
I just need to blast and paint the bits, I did find an issue though
The threads in this nut are shagged, anyone know the thread size so I can get a replacement? Also the studs on the half shaft. The threads are acceptable at a push but it would be nice to replace them, has anyone had the studs out before? And where can I get replacements?
Thanks
Re: Tramps Truck,
Post by ScottieJ » Sun Nov 29, 2015 8:29 pm
M12x1.25 I think same as wheel nuts. Muddyzook used to sell them new.
