Kiwizook's resto
Re: Kiwizook's resto
Post by Anton » Wed Dec 17, 2014 11:45 pm
donkeychomp wrote:err...why did I just see Anton's face in his avatar? Now it's a car. Am I that drunk?
Press F5 a few times.
Post by ROBBIE » Thu Dec 18, 2014 9:56 am
The scary one :shock:
kiwizook
Post by kiwizook » Thu Jan 08, 2015 5:37 am
completely rebuilt and painted front axle
and then I finally installed and plumbed in the fuel system
and after that decided to install my air tank for the compressor in the spare wheel carrier, as I'm going to slightly change the back, and a spare wheel won't fit under the deck any more then anyways
air tank
air tank
and best of all, recieved my brand new welder today! inverter welder, 10-200A, arc, mig and tig all in one machine, we did a test run with it, and it weld's so super smooth, I love it! the guy that sold me the welder is a friend of mine, and he hassled his supplier into sending a brand new auto darkening helmet too, so I'm really happy with it!
Fwb2700
Post by Fwb2700 » Thu Jan 08, 2015 7:00 am
Nice welder wish the welder I am using was mine unfortunate it's borrowed. Where did you get the air tank from?? I am wanting something similar for my sj. I have plenty of room where the fuel tank normally goes as I am running a plastic boat fuel tank
1984 Suzuki SJ410q Winch Truck (Work in Progress)
kiwizook
Post by kiwizook » Thu Jan 08, 2015 9:19 am
I picked up this tank at the scrap yard, it is made of two dive tanks welded together, and has a pressure gauge and safety valve on it, with all brass fittings brazed together to prevent leaks
zook123
Post by zook123 » Thu Jan 08, 2015 3:11 pm
Certainly coming together, looking forward to seeing the end product!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Post by donkeychomp » Thu Jan 08, 2015 8:07 pm
Amazing work...love this build!
kiwizook
Post by kiwizook » Mon Jan 26, 2015 8:56 am
so I've finally put the cab back on the chassis, sealed the footwell and glued new sound deadening in there, used the proper bostik stuff you have to apply with a heatgun, and also put some sound deadening on the back of the cab, and painted it. it's finally getting there, I'll see if I can get some pics of it later
Post by Anton » Mon Jan 26, 2015 3:19 pm
I'd love to know how much of a difference the sound deadening makes, I've always wanted to make my SJ a touch more civil for longer journeys...
kiwizook
Post by kiwizook » Mon Jan 26, 2015 6:37 pm
seeing mine has a lot of relatively flat sheet metal right behind the seats, it probably makes a lot of difference, and I wanted to cover up my welds, so the transport people can't complain about it when it gets re-registered :D
one thing to watch out for though is the fact that it can trap water and rot your body out. if you use it, make sure you seal the surface first with lacquer or something similar, so trapped water doesn't do any damage. or use por15 under it if you're feeling rich!
