Project KJA
ianedwards
Re: Project KJA
Post by ianedwards » Wed Feb 18, 2015 6:45 pm
tank touching the dif :er:
Ian. :)
ianedwards
Re: Project KJA
Post by ianedwards » Wed Feb 18, 2015 7:23 pm
bed needs to go up, :twisted:
Ian. :)
Rhinoman
Re: Project KJA
Post by Rhinoman » Wed Feb 18, 2015 9:51 pm
Why did you move the tank?
ianedwards
Re: Project KJA
Post by ianedwards » Thu Feb 19, 2015 10:32 am
the ram needed to go where the tank was, so I had to move it back a bit, but as it was spoa, it wasn't a problem.
Ian. :)
Re: Project KJA
Post by ScottieJ » Thu Feb 19, 2015 11:16 am
What a nightmare after all the work that's been put into it. :thumbdown:
ianedwards
Re: Project KJA
Post by ianedwards » Thu Feb 19, 2015 4:13 pm
Not really, it is a pain but im happier with it lower, looks better. And probably will feel nicer to drive.
I've got some 75 x 50 box now, so all ive got to do is cut bits to go on the 6 bed supports and cut the rear tipping points off and add the box In between, will probably make it all to bolt on, will make less mess.
I've got an idea for another bed in the future so if I make the brackets bolt on, I've only got to build another frame, :)
Ian. :)
ianedwards
Re: Project KJA
Post by ianedwards » Sun Mar 01, 2015 9:40 pm
I've got all the welding finished tonight, back is now 75mm higher, giving rear wheels a bit more room.
just got to lift the tank, bit of paint, put the lights back on and job done.
Ian. :)
Re: Project KJA
Post by donkeychomp » Sun Mar 01, 2015 9:42 pm
Amazing work matey!
Re: Project KJA
Post by Anton » Mon Mar 02, 2015 12:30 am
:popcorn:
Re: Project KJA
Post by Jordi » Mon Mar 02, 2015 9:59 am
So when do we all get to see this creature in the flesh?
