Scottie's Zuke. Blue
Re: Scottie's Zuke
Post by ScottieJ » Sun Mar 17, 2013 10:44 am
A better pic
Re: Scottie's Zuke
Post by Anton » Sun Mar 17, 2013 11:37 am
Is that a full floater, or just uprated shafts?
suzukisteve
Re: Scottie's Zuke
Post by suzukisteve » Sun Mar 17, 2013 12:07 pm
lookin good dude! :guns:
pickle power!
Re: Scottie's Zuke
Post by Jordi » Sun Mar 17, 2013 4:42 pm
Thats the front axle so it'll just be shafts.
Looks well Scottie. Is that the "scrap" hood you ever so carefully removed from Mikes?
Re: Scottie's Zuke
Post by ScottieJ » Sun Mar 17, 2013 5:51 pm
Anton wrote:Is that a full floater, or just uprated shafts?
I've only fitted my front axle so far, it has trail tough 4340 chromo shafts and CVs in, I'm going to start getting the rear axle ready to go on over the next few weeks, that is a full floater and is being fitted with an ARB air locker :brows:
Cheers Steve :mrgreen:
And yeah Jordi that Is the top from mike that I carefully removed :lol:
Re: Scottie's Zuke
Post by ScottieJ » Sat Mar 30, 2013 12:04 am
:er: SJ420 :brows: :brows: :brows: or should it be SJ2000? :brows: :brows:
OllieSJ
Re: Scottie's Zuke
Post by OllieSJ » Sat Mar 30, 2013 10:13 am
I say bung it in the lwb
Re: Scottie's Zuke
Post by Edweird » Sat Mar 30, 2013 2:52 pm
SJ2000 sounds like a Knight Rider car.
"I am the Suzuki Jimny 2000. SJ if you prefer. I am equipped with the latest in Rockwatt fabrication and all terrain technology."
ferris
Re: Scottie's Zuke
Post by ferris » Mon Apr 01, 2013 10:49 am
Will that engine just marry up to your existing transmission, or is there going to be a bit more to it than that?
Should be pretty poky when you get it in there :guns: .
Re: Scottie's Zuke
Post by ScottieJ » Wed Apr 03, 2013 11:37 pm
ferris wrote:Will that engine just marry up to your existing transmission, or is there going to be a bit more to it than that?
Yeah should go pretty well I think :guns:
All I need is to get a vitara flywheel machined so that it bolts up to the J20a crank, the bell housing pattern is the same so should be a nice and simple swap, the hardest part will be the wiring but even that looks pretty simple, I will need to get an ECU from a manual though because the ECU in the autos also controls the gearbox and will throw up some codes if the auto isn't hooked up.
