Jordis 1988 Samurai (Re)Build
Post by Jordi » Thu Oct 30, 2014 10:30 pm
4.3 R&P acquired!
Need to strip another set of rear side gears then the diffs are of to be rebuilt. So I can fit 26spline shafts in the front.
Hoping the budget will stretch to a Chinese arb for the rear too
Post by donkeychomp » Fri Oct 31, 2014 12:02 am
Is the Chinese ARB up to the job? Last thing I bought from there was an HDMI lead and it worked worse than my old scart cable.
Post by Jordi » Fri Oct 31, 2014 6:28 am
donkeychomp wrote:Is the Chinese ARB up to the job? Last thing I bought from there was an HDMI lead and it worked worse than my old scart cable.
General reviews seem pretty good, quite a few of the Australian forums rate them well.
Post by Anton » Sat Nov 01, 2014 1:48 pm
If they're as strong as standard diffs, then they'll probably be stronger than the shafts, meaning they should hold up ok.
Then there's probably the thing about driving more sensibly with a truck built out of parts that you don't trust as much...
Post by Jordi » Sat Nov 01, 2014 2:09 pm
Stronger than chromo shafts though?
It's all down to will I have the cash for the locker when I get the diffs built up?
Post by Anton » Sat Nov 01, 2014 3:20 pm
I need to learn to build up diffs.
Post by Jordi » Sat Jan 17, 2015 3:49 pm
Not much of an update. Still collecting / waiting on parts.
Few bits in the post.
Post by ScottieJ » Sat Jan 17, 2015 5:10 pm
Big spender :rockin:
Post by Jordi » Sat Jan 17, 2015 6:11 pm
ScottieJ wrote:Big spender :rockin:
It's the front shafts Scottie, they are Zuk Porn!!!!
Post by ScottieJ » Sat Jan 17, 2015 8:49 pm
I'll prob buy a set at some point. So I can use my old chromos in the Lwb. Tbh I've had not even the slightest of worries about the TT chromos, they've certainly taken the abuse over the years.
