Fwb's SJ410 Build
Re: Fwb's SJ410 Build
Post by twiss » Tue Mar 31, 2015 4:33 pm
remember if you are using a sammy gearbox you need the sammy flywheel on there too :)
Fwb2700
Post by Fwb2700 » Tue Mar 31, 2015 6:42 pm
I have most of a g13a so have that already too just deciding which gearbox to use
1984 Suzuki SJ410q Winch Truck (Work in Progress)
Fwb2700
Post by Fwb2700 » Sun May 03, 2015 7:13 am
I might be able to finally do some work on the truck again next week. Just finished moving house. Have moved all my tools built a workbench. Mounted the drill press and bench grinder and wired up some lights and powerpoints.
Post by donkeychomp » Sun May 03, 2015 6:57 pm
That's bigger than my flat!
Post by ScottieJ » Sun May 03, 2015 7:49 pm
That's too tidy.....you need to get the 410 in there and make it look used :lol:
Fwb2700
Post by Fwb2700 » Sun May 03, 2015 8:10 pm
The 410 is in there i standing on it. Just to make you all hellions I wasn't going to say but that's the workshop part I'm standing in a double garage on the front. And the pit is open and dry as a bone my g16a down there currently as we have a chain block
Fwb2700
Post by Fwb2700 » Mon May 04, 2015 3:26 am
Finally managed to get some work done on the zuk. Passenger floor finally in and mostly welded into place.
Still thinking about chopping the rear end off and making it into a tubular rear
Fwb2700
Post by Fwb2700 » Sun May 17, 2015 7:09 am
Started building my rocksliders today. Took a while to work out how I wanted to mount them. Going to weld them straight to the chassis going to be extremely strong but not too heavy
Post by Jordi » Sun May 17, 2015 12:31 pm
Fwb2700 wrote:Started building my rocksliders today. Took a while to work out how I wanted to mount them. Going to weld them straight to the chassis going to be extremely strong but not too heavy
Take it you'll be bracing / reinforcing the chassis where they mount.
Fwb2700
Post by Fwb2700 » Tue May 19, 2015 7:56 am
No turning back now
