Page 8 of 11
Re: Joes build. 416 samurai.
Posted: Sun Jul 14, 2013 6:04 pm
Samurai sump will bolt on but requires the 413 oil pick up fitting and modifying. It also holds less oil if i remember rightly. Its not a major job.
Most of us are running lift springs with extended bump stops to stop them hitting.
Posted: Sun Jul 14, 2013 6:05 pm
by mk1joe
sweet mate, il add it to the list.
i doubt many of you are that fussed about going fast either, lol
Posted: Sun Jul 14, 2013 6:10 pm
Ha ha, i'm a speed demon bud!
Mine will do 60 ok. Haven't had it on a decent road to see how fast it'll go. Not with an accurate speedo anyway.
Posted: Sun Jul 14, 2013 6:58 pm
by mk1joe
i better look at getting a high lift cam and a supercharge induction kit then.
or could the 8v handle a turbo? hmmm......
Posted: Sun Jul 14, 2013 8:13 pm
by turbo-tom
Think Twiss is looking at perfomance upgrades ie turbos etc but he is running. a 16valve.
Posted: Mon Jul 15, 2013 11:48 pm
by donkeychomp
Bonnet badge in the post tomorrow, let me know when it turns up.
Posted: Tue Jul 16, 2013 9:16 am
If your SU is set up for a 1.3 then you need a different spring and needle otherwise you will not see the full power potential. What did you set the timing to?
Posted: Tue Jul 16, 2013 12:38 pm
by mk1joe
I didnt use my su carb because it has one of those rubish elbow adapters. So im using my niki at the moment, and I put it on the emmisions machine and set it so its burning eficiantly.
And I set the timing to 10o btdc.
Posted: Tue Jul 16, 2013 1:02 pm
Something is off somewhere then as mine will breeze past 50 running 33s :er:
Posted: Tue Jul 16, 2013 6:02 pm
by mk1joe
Yea, its a bit anoying as I expected lots from a one six:( managed to get it to 60 today but it didnt feel like it wanted to do much more. I imagine the niki carb should be good enough? And the standard 1.3 exhaust shouldt make that much difference should it?
