Page 8 of 9
Re: suzuki steve's 410 build
Posted: Thu Jun 27, 2013 9:55 pm
by suzukisteve
i did too, thats how i found the filler and fiber glass :hahaha:
Posted: Thu Jun 27, 2013 9:58 pm
by dndnk
is that filler a factory fit my rear arches where covered in it :rockin:
Posted: Thu Jun 27, 2013 10:47 pm
by dan_2k_uk
Cool. If I get a bit of time at work tomorrow I will write it using my full set of VL photos and then move the other posts and input from this thread there and generally tidy it up.
Posted: Thu Jun 27, 2013 10:50 pm
Good stuff. When i do my new front clip with the joggled / over lapped panels i'll ad that method to it.
Unless i make a total cock up of it, in which case none of you will ever hear about it.
Re: Virtual lift Q&As
Posted: Fri Jun 28, 2013 10:21 am
by suzukisteve
guys then I vl the front clip am I gonna need to relocate my battery? as I run a bigger than standard one :er:
Posted: Fri Jun 28, 2013 11:01 am
suzukisteve wrote:guys then I vl the front clip am I gonna need to relocate my battery? as I run a bigger than standard one :er:
Probably not
I have done the biggest possible virtual lift you can while keeping the front clip and my battery is still on the inner wing, I also run a bigger battery than standard, think it's a 064?
Posted: Fri Jun 28, 2013 12:22 pm
by suzukisteve
yeah looks to be an 063 or 064. thats good news then, gonna run a twin battery I think
Posted: Fri Jun 28, 2013 2:15 pm
right here's pics of my VL, with 100% new inner wings and a raised rear bed to I could run longer shocks.
Pretty much the most you can physically remove while keeping the SJ looking like and SJ in my opinion, good for 33s with no lift and possible 34/35s
Posted: Fri Jun 28, 2013 5:14 pm
by turbo-tom
you can go more then Scott if you wanted too! :shock: but i reckon Scott's looks about right before it starts to look gash.
Posted: Fri Jun 28, 2013 9:18 pm
by dan_2k_uk
I run a 063 in the standard position with the VL method I described no problems.
Steve I have edited your first post after the thread split to make this topic make sense, Hope you don't mind. :thumbup:
