Hi guys.
I've had loads of electrical problems with my '89 Santana over the lest few weeks. Everything from headlights occasionally working and the ignition just stopping whilst driving. I found the problem was the fuse box. A passenger has at some point put their foot against it, and it has cracked the PCB bit of the board. But, instead of replacing it with a equally venerable Santana fuse box, I was wondering if anyone has ever replaced one with a aftermarket fuse holder? And has anyone got a diagram on what fuse does what? I've figured some out but not all of them.
Thanks
Huw
Santana Fusebox
- HuwJones
Santana Fusebox
There's three ways of doing things,
1) The Right Way,
2) The Wrong Way
3) My Way.
2 & 3 are usually the same.
1) The Right Way,
2) The Wrong Way
3) My Way.
Re: Santana Fusebox
It would be easier to just replace it rather than re-wire the thing, my Sammy has the fusebox under the drivers side dash, but could you just move it more upwards and out of the way of people feet?
Re: Santana Fusebox
Going by this santana diagram http://forum.suzukiclubuk.co.uk/vi ... =11&t=2097 we have this
- Spanish SJ fuse board.jpg (225.73 KiB) Viewed 6103 times
Re: Santana Fusebox
Ooh I see what you mean now by crappy fuse box!
- donkeychomp
Re: Santana Fusebox
Pretty sure I have a fusebox kicking about in the garage somewhere.
- HuwJones
Re: Santana Fusebox
Thanks, That is very helpful! It's also very interesting, my fuse box/panel/board thing, has the same 'burn' marks on the white connector. When I bought it, the 15Amp (blue) fuse above it was melted (I mean literally melted, not fused). It's all a bit shit really! I thought it was because the previous owner had done something funny with the wiring, but it could be a 'Normal' Santana loom problem.Darrell wrote:Going by this santana diagram http://forum.suzukiclubuk.co.uk/vi ... =11&t=2097 we have this
Donkeychomp, if you've got one, what would you want for it?
Thanks
Huw
1) The Right Way,
2) The Wrong Way
3) My Way.
1) The Right Way,
2) The Wrong Way
3) My Way.
Re: Santana Fusebox
These are the pictures I have in my archive, including the one with the wire colours shown. I gave up finishing it as I don't know the rest of the wire colours.
Any chance of a pic or 2 of yours , or have you chopped the connectors off.
Cheers - Darrell.
Cheers - Darrell.
- IMAG0105 (2).jpg (311.26 KiB) Viewed 6075 times
- IMAG0106.jpg (286.98 KiB) Viewed 6075 times
- IMAG0108.jpg (229.68 KiB) Viewed 6075 times
- IMAG0109.jpg (242.66 KiB) Viewed 6075 times
- IMAG0105.jpg (170.07 KiB) Viewed 6075 times
