FUEL TANK
Re: FUEL TANK
Vent pipe runs off the top of the tank onto a pipe on the fuel filler neck on the inside of where the fuel cap is.
Re: FUEL TANK
Okay thanks for the info....loud bangs make me jittery
jim
jim
Re: FUEL TANK
Every time i undo the fuel cap there is a loud hissing as though it is pressurized until cap is released
i guess this is normal on my sj413 anus
jim
jim
- Ladaman
- Suzuki Guru
Re: FUEL TANK
It doesn't sound normal to me. I'd suggest the vent/breather pipe is blocked. The hissing will be air rushing into the tank.
Does it run okay on long journeys, as I'd expect issues if the vent was blocked?
Re: FUEL TANK
Yes its done it for many years ...journey of 80 miles no problems.....
Jim
Jim
- Ladaman
- Suzuki Guru
Re: FUEL TANK
Don't worry then. ![;) ;)](./images/smilies/icon_wink.gif)
Re: FUEL TANK
It is normal, mine used to do it all the time, behind the fuel filler cover in the back there is the one way 'breather' valve (it's orange and black) you can take it out and blow through it to make sure it is ok, I took mine out because of this 'sucking' and replaced it with an inline filter but it made no difference to running, so I put it back in! speaking to people on here made me realise it's normal.
Re: FUEL TANK
Thanks its such a loud hiss we thought it might be a snake trapped in there ......
cheers Jim
cheers Jim
- Ladaman
- Suzuki Guru
Re: FUEL TANK
It could be a fuel ADDER tive
![:D :D](./images/smilies/icon_biggrin.gif)
