A question of stability
Marc
Post by Marc » Fri Jul 25, 2014 6:56 am
just a quick question guys on my 410 when driving at speed 45-50 mph on the motorways i am getting a big sway, i have taken all the weight off the roof rack and packed it lower down, springs and shocks seem ok could it be low tire pressures at the moment they are 20 front and 26 rear, it is not the trucks passing or crosswinds
Re: A question of stability
Post by ScottieJ » Fri Jul 25, 2014 10:25 am
Does it only do it on motorways?? Might just be tramlining. Often on the inside lane 2 small dips form from the weight of all the lorries. Because of the SJs narrow track you don't fit in these and it cause bump steer etc.
best way to avoid it is to drive A roads....it's not like you are in a fast car so why not enjoy nicer more scenic routes :lol:
Marc
Post by Marc » Fri Jul 25, 2014 12:56 pm
hi Scotty,
Thanks for the swift responce but it happens on normal roads as well
Post by ScottieJ » Fri Jul 25, 2014 1:06 pm
What exactly do you mean by a sway??? As in the sj is steering itself, a wobble, vague steering?
Post by twiss » Fri Jul 25, 2014 2:46 pm
Have a look at the rag joint at the bottom of the steering column. Mine started to go and it made the steering very loose!!!
Marc
Post by Marc » Fri Jul 25, 2014 7:58 pm
no the steering is fine it is the car that is rocking from side to side, so much so that if you do not take your foot off the throttle I feel it would topple over
Post by ScottieJ » Fri Jul 25, 2014 8:57 pm
:hmm: This sounds strange? Are there any bad vibrations?? Gear and tbox levers shaking around like mad etc?? I would whip all the props off to check any UJs haven't gone dry and seized up. Also check the engine mounts, they need to be removed to inspect them. If ones failed I guess it could cause the sj to rock at certain speeds???
:hmm:
Post by Edweird » Fri Jul 25, 2014 9:35 pm
Wow, that sounds really odd. Have you got a tyre bulge perhaps?
Post by donkeychomp » Fri Jul 25, 2014 10:23 pm
and why are you running 20psi front 26 rear? The front is way to low.
Post by Jordi » Fri Jul 25, 2014 10:28 pm
If you're on standard size tyres try 25psi in the front.
