Engine not starting but did a couple weeks ago??
Jordanquin
Post by Jordanquin » Tue Aug 05, 2014 4:48 pm
When I picked the truck up it had to be jump started due to a dead battery, no I've charged the battery and there are 11.4volts running through it and I've wired up my electronic fuel pump to a jerry can like I did last time but the engine is not even turning over??
Is there a simple solution to this or is it going to be difficult to diagnose the problem?? I'm leaning towards the started but it worked fine a couple weeks ago and the engine started first time and ran sweet??
Re: Engine not starting but did a couple weeks ago??
Post by Darrell » Tue Aug 05, 2014 6:53 pm
Try jump starting it again, that voltage is low for a charged battery.
Jordanquin
Post by Jordanquin » Tue Aug 05, 2014 7:33 pm
Ok, does this mean the battery is knackered then? I had in on charge for about 8 hours?
timwilks13
SCUK Website Padawan
Post by timwilks13 » Wed Aug 06, 2014 9:32 am
either that or your battery charger, but i would be inclined to think its the battery. Mine only reads about 11.9V and i dont get many chances to start the car before it dies, so yea 11.4 sounds too low, new battery time! Oh and buy new, i know they're dear for a decent battery, but i used to buy £15 scrap yard jobbies, only ever lasted couple of months each.
Jordanquin
Post by Jordanquin » Wed Aug 06, 2014 5:29 pm
Ok guys. I have a saxo sat in the yard so I'm hoping I can use a brand new battery from that :)
Jordanquin
Post by Jordanquin » Fri Aug 08, 2014 4:38 pm
Me and my mate had a look at the problem and the starter was completely stuck so we took off the spade and just used a screwdriver and it started again so he said to clean it all, are there any guides on here anywhere on how to strip it down and recondition it?? Thanks.
Post by twiss » Fri Aug 08, 2014 4:40 pm
Starter is pretty easy to strip down and recon, but I don't think there are any guides....
Will explain on FB as its easier ;)
