turbo lag
RobH
turbo lag
Post by RobH » Fri Sep 26, 2014 1:51 pm
hi guys iv got a 2ltd lwb gv is there any think i can do to improve turbo lag
thanks rob
timwilks13
SCUK Website Padawan
Re: turbo lag
Post by timwilks13 » Fri Sep 26, 2014 1:54 pm
Improve it or reduce it?
RobH
Re: turbo lag
Post by RobH » Fri Sep 26, 2014 1:58 pm
at junction it takes a few seconds be it kicks in or is that normol
shredder
Re: turbo lag
Post by shredder » Fri Sep 26, 2014 4:38 pm
surely the only way to reduce lag (asuming everything is working) is to move the turbo closer to the exhaust ports?
Re: turbo lag
Post by Edweird » Fri Sep 26, 2014 9:06 pm
Smaller turbo would also do it, or a variable geometry turbo.
kiwizook
Re: turbo lag
Post by kiwizook » Fri Sep 26, 2014 11:31 pm
dual turbo setup, one small turbo, and one big one would also do it. but the "problem" you are referring to is just normal. it will always take a little bit to spool up the turbo, it's simply how they work
Re: turbo lag
Post by Anton » Sat Sep 27, 2014 6:15 pm
Edweird wrote:Smaller turbo would also do it, or a variable geometry turbo, but now we're entering supercar type gear.
Not really, Toyota fitted a variable vein geometry turbo to my Yaris. A bit of research and you can probably find a suitable sized one from another vehicle somewhere.
Most modern TD engines have them now, so depending on the age of his vehicle, he may already have one.
If not, the turbo on a more modern Zuk TD (I think that the modern ones are 1.9, so maybe he doesn't) are probably VGT/VTG turbos, and may even be a bolt on swap.
