turbo lag
Posted: Fri Sep 26, 2014 1:51 pm
by RobH
hi guys iv got a 2ltd lwb gv is there any think i can do to improve turbo lag
thanks rob
Re: turbo lag
Posted: Fri Sep 26, 2014 1:54 pm
by timwilks13
Improve it or reduce it?
Re: turbo lag
Posted: Fri Sep 26, 2014 1:58 pm
by RobH
at junction it takes a few seconds be it kicks in or is that normol
Re: turbo lag
Posted: Fri Sep 26, 2014 4:38 pm
by shredder
surely the only way to reduce lag (asuming everything is working) is to move the turbo closer to the exhaust ports?
Re: turbo lag
Posted: Fri Sep 26, 2014 9:06 pm
by Edweird
Smaller turbo would also do it, or a variable geometry turbo.
Re: turbo lag
Posted: Fri Sep 26, 2014 11:31 pm
by kiwizook
dual turbo setup, one small turbo, and one big one would also do it. but the "problem" you are referring to is just normal. it will always take a little bit to spool up the turbo, it's simply how they work
Re: turbo lag
Posted: Sat Sep 27, 2014 6:15 pm
by Anton
Edweird wrote:Smaller turbo would also do it, or a variable geometry turbo, but now we're entering supercar type gear.
Not really, Toyota fitted a variable vein geometry turbo to my Yaris. A bit of research and you can probably find a suitable sized one from another vehicle somewhere.
Most modern TD engines have them now, so depending on the age of his vehicle, he may already have one.
If not, the turbo on a more modern Zuk TD (I think that the modern ones are 1.9, so maybe he doesn't) are probably VGT/VTG turbos, and may even be a bolt on swap.
