SU Carb Value
AshR1
SU Carb Value
Post by AshR1 » Sat Oct 11, 2014 12:05 pm
got an old su carb and mount from my old engine, it was a bit tatty and had some cable ties holding it together but still worked ok, anybody know the value of it if its worth selling or keeping it?
thanks
A Newbie with a 1988 Samurai Hard-Top
Re: SU Carb Value
Post by Jordi » Sat Oct 11, 2014 12:57 pm
AshR1 wrote:got an old su carb and mount from my old engine, it was a bit tatty and had some cable ties holding it together but still worked ok, anybody know the value of it if its worth selling or keeping it?
thanks
SU carb elbow adaptor about £15. SU carbs go from about £35 to £75 depending on condition and setup.
AshR1
Re: SU Carb Value
Post by AshR1 » Sat Oct 11, 2014 2:21 pm
thanks, well if anybody is interested have the elbow and the carb but no hoses, can have them both for £40, i'll get some pics up of the carb though, like i say it worked but its not the best example of one
AshR1
Re: SU Carb Value
Post by AshR1 » Sat Oct 11, 2014 2:40 pm
it did have a sticky throttle but i just used a spring and washer on it and it worked fine after
Re: SU Carb Value
Post by ScottieJ » Sat Oct 11, 2014 10:50 pm
That's an old HS style carb, most people want HIF carbs.
Re: SU Carb Value
Post by twiss » Mon Oct 13, 2014 9:27 am
Its just an H carb actually ;)
The HS carb has an external fuel hose connecting the float chamber to the carb...
Re: SU Carb Value
Post by Anton » Wed Oct 15, 2014 7:48 pm
If that's the case, might actually be worth more to the MG, Rover, Jag or Austin communities.
