Hello from isle of wight
hi im jasper from isle of wight uk
bought my first zuni yesterday i believe it belonged to a old member on here called angie
unfortantley some young fool bought it and has wrecked it so i will be starting the job of returning to a good standard level
don't have any pictures as of now but will get some tomorrow
the guy i bought it off has done a 3inch body lift which is of very bad quality so as of tomorrow i will be trying to solve this
nice to meet you all
- Ladaman
- Suzuki Guru
Re: Hello from isle of wight
to the club.
Look forward to some pics. What is it SJ, Vit or Jimny?
Welcome to SCUK.
Fairly sure it's an SJ
its a sj 410
just found a picture but looks very different was dark by the time i got it home so couldn't get any today yet alone asses the damages too much!
this is it not in the best of states was going to buy it about 5 months ago but unfortunately could not and someone else got it and ruined it!
- 10153062_10202378426290859_1840236861449555545_n.jpg (185.59 KiB) Viewed 6220 times
Body lift - I did that to mine. And un-did that to mine. Yuk.
Welcome, and good on you for rescuing the wee beastie.
To the club. I remember that truck. Hopefully you can get it back to its former glory
So started accessing damage today and is slightly worse than I thought!
The winch is broken with cable fully out when pushing the controls the control box just clicks? Any ideas?
Whole rear left hand arch and side is rusted very badly
Hope I haven't bitten off more than I can chew!
Won't let me upload pictures straight from my phone!
Will upload to laptop later
Hi and welcome. Yeah I remember that.
If you're lucky the winch will just be a bad connection in the solenoid pack.
done lots of inspecting working out what needs doing and my god can't believe how quick a car can get ruined in such a small amount of time!
hopefully i can get a few pointers from all you more experienced zuki owners!
- so the body life has been done with strange blocks like this not much welding just bolts all the way through!
to undo this action is it a easy process? can i remove them two at a time?
if the previous owners have extended brake hoses etc will i have to shorten ?
the gearbox still has same transition as it sits 3 inches under the body!!
i am a complete noob when it comes to this - IMG_0611.JPG.jpeg (402.86 KiB) Viewed 6170 times
- where the hard top has been sitting on side panel lots of rust will this be repairable?
(had to use saw dust to soak up spilled gear box oil covered basically the whole car!) - IMG_0624.JPG.jpeg (453.47 KiB) Viewed 6170 times
- this is how the gearbox is currently sitting
not to good? - IMG_0627.JPG.jpeg (456.93 KiB) Viewed 6170 times
- you can see through where rear left arch is completely deteriorated hopefully repairable not so sure on how to go about doing this
- IMG_0625.JPG.jpeg (477.06 KiB) Viewed 6170 times
