GV1600 54 Plate, Wheel Skipping
souleh
Post by souleh » Mon Dec 15, 2014 12:22 pm
Hi Guys,
I recently got a GV1600 Sport 3dr and it appears that when on full lock in 2wd the front drivers side wheel will skip along. Has anyone seen this before or maybe knows where I should start to look??
Thanks :D
Re: GV1600 54 Plate, Wheel Skipping
Post by ScottieJ » Mon Dec 15, 2014 1:23 pm
Could be a tracking issues maybe? might be a good idea to get the alignment checked.
souleh
Post by souleh » Mon Dec 15, 2014 1:30 pm
It is going in for new tires tomorrow, I have heard that alternate tread patterns can cause different traction and it appears whoever had it before me wasn't worried about matching the tires up.
Whilst its in I will get them to check the tracking.
Ladaman
Post by Ladaman » Mon Dec 15, 2014 1:43 pm
I'd mention it to the tyre fitters. They can give the wheel a wiggle to check all the bearings and ball joints out. It should be fairly obvious then what the problem is.
souleh
Post by souleh » Tue Dec 16, 2014 2:21 pm
They had a jiggle and a poke, seems all is fine mechanically.
From the limited time driving with the new tires it appears to have solved the problem, I will need to do some further testing though.
souleh
Post by souleh » Wed Dec 17, 2014 6:32 pm
Tested and it appears to be sorted. :)
Post by Anton » Wed Dec 17, 2014 7:00 pm
souleh wrote:I have heard that alternate tread patterns can cause different traction
This is very weird as I'd have thought that in 2wd, the difference in traction between one tyre and another wouldn't really matter that much unless in an emergency braking situation or something - but since you sorted it with new tyres, it seems to be true! You live, you learn!
For safety's sake, it's probably best to have good, well matched tyres on it anyway.
souleh
Post by souleh » Thu Dec 18, 2014 11:15 am
I literally looked a right pudding testing it out at the car park at work :P
Post by dan_2k_uk » Thu Dec 18, 2014 9:19 pm
The outside wheel turns a different radius to the inside. All cars do this when at full lock but its more noticeable with slightly chunkier tyres and a bit more weight. Hence the squealing in multistory carparks.
Post by ScottieJ » Thu Dec 18, 2014 9:28 pm
If the tracking is correct then you should have the correct ackerman angle and shouldn't get any tyre scrub.
