X eng prop brake
X eng prop brake
Post by andyrew » Fri Dec 26, 2014 4:17 pm
I fitted a prop brake on to the tin top so im no in
Need of another tbox brake.
I thinking of going for the x eng set up but remember these
Having bad reviews years ago. Anyone able to share their
Experiences?
If you've bought one would you bother again?
Re: X eng prop brake
Post by Jordi » Fri Dec 26, 2014 4:22 pm
Dan and Scottie run them. Fairly sure they both have good reviews.
Im fitting one in my rebuild.
Post by andyrew » Fri Dec 26, 2014 4:33 pm
Did you get yours new? Thae price is the bit that puts me off
I don't want to shell out for something thats just as good
As the standard drum.
Im in two minds of finish or breaking the thing :lol:
So would like to keep costs to finish it down.
Post by ScottieJ » Fri Dec 26, 2014 6:37 pm
They work very well......after a few modifications, also there are two cables available for them, make sure you get the one that is actually flexible as the routing isn't very good and it needs to go around a tight bend, if you have the stiff cable it causes release issues.
Post by Jordi » Fri Dec 26, 2014 6:50 pm
Buying mine second hand. £100
Post by andyrew » Fri Dec 26, 2014 7:11 pm
Cheers guys.
The replacement pads seem a bit pricey for what they are
Il keep an eye on fleabay for one then. If not ill
Track down as drum. im sure richard must be inundated
With them come to think about it :lol:
Post by twiss » Fri Dec 26, 2014 8:34 pm
I've put a drum on mine and its a lot better than the samurai axle handbrakes
Richard sorted mine out for me :)
Post by ScottieJ » Fri Dec 26, 2014 9:34 pm
The standard drums are good unless you are in mud a lot, then they need to be adjusted quite often.
Post by Anton » Sat Dec 27, 2014 2:53 am
I bought one new aaaaaages ago, but I still haven't gotten around to fitting it! :D
steve greenc3
Post by steve greenc3 » Fri Jan 02, 2015 10:24 pm
I bought a new x-brake, price seems a lot, but worth it. Does need regular adjustment if used on constant deep mud winch challenges but overall a big yes from me!!!!!!!!!!!!!!!
