original early 1980s Suzuki stereo
Does it exists?
Re: original early 1980s Suzuki stereo
My kja had its original radio
It was a clarion mw lw with one speaker. The face of the radio
Was the whole panel in the dash pod. Including
The cig lighter into it.
Thanks. I'm restoring a 1982 Sj410. Trying to get as much original things as possible. do you know where to get a picture of it?
Ahh right. 82 id assume thats a metal dash?
Mine was an 87 so had the later plastic dash.
LJ80 one was very similar, if not the same?
- rad.jpg (7.19 KiB) Viewed 10184 times
intresting
. I will search the net to try and find one. Thanks
A lot of those early 80s ones were actually fairly standard, the 2 knobs were always in the same place and the center part was the same size cutout weather it had the 'memory' buttons or a tape slot or not.. where you would find one that still works I don't know
I've still got mine, and it's working, so I'm keeping it, but I could take a pic of it when I come back from my trip, so you know what exactly you're looking for
Great thanks
I don't think that they came with a radio but there was probably one available as an accessory, there was a fitting kit that went under the dash, above the gear lever and that took a standard sized radio.
