Diff guards
Josh-holden
Diff guards
Post by Josh-holden » Sun Jan 04, 2015 11:26 pm
Where can i get some weld on diff guards from?
Re: Diff guards
Post by donkeychomp » Mon Jan 05, 2015 1:40 am
Firstly that's a very bad idea...why would you weld them on? You'll need to take them off to access other areas. And it isn't rocket science. Measure up and cut some steel and bolt them on.
Re: Diff guards
Post by ScottieJ » Mon Jan 05, 2015 9:01 am
Mine are welded on. They are made using 8" steel pipe caps
Ladaman
Re: Diff guards
Post by Ladaman » Mon Jan 05, 2015 12:36 pm
ScottieJ wrote:Mine are welded on. They are made using 8" steel pipe caps
I like that idea. I was wondering what to use on mine, as I've "dinked" them, and don't want them to get worse.
There might be a chat with a local fabricator this afternoon. :D
Josh-holden
Re: Diff guards
Post by Josh-holden » Mon Jan 05, 2015 2:00 pm
The reason I want to weld them on is because iv heard that bolt on ones bend easier.
Re: Diff guards
Post by ScottieJ » Mon Jan 05, 2015 3:12 pm
You only need to protect the diff pan anyway so welding it on won't cause any issues. I would add bigger drains than the ones on mine though, it's a nightmare to get all the mud out with only a small drain hole :lol:
Re: Diff guards
Post by donkeychomp » Mon Jan 05, 2015 5:02 pm
Mine's bolt on for that reason...all the crud that collects in there is just going to cause rust issues and less you can take it off and clean everything!
Re: Diff guards
Post by ScottieJ » Mon Jan 05, 2015 5:18 pm
I just hose mine out when I clean the rest of the vehicle
Re: Diff guards
Post by Anton » Mon Jan 05, 2015 5:32 pm
Scottie - how much were the pipe caps?
mattmiles
Re: Diff guards
Post by mattmiles » Mon Jan 05, 2015 5:53 pm
Its a real shame Rob no longer makes these. Have a pair on mine, work a treat.
Matt
