Hello again, grand vitara suspension help?
Rodden87
Post by Rodden87 » Sun Feb 08, 2015 7:06 pm
Hello chaps, I hope a few of you might remember my jimny build from a laning trip we did last year. Well after selling the jimny and buying a defender (the biggest regret ever) I'm now desperate to return to zooki's. I'm considering a Gv lwb and would love some advice on lift and trimming required for roughly 31-32 inches tires.
I'm also going to be keeping my winch so any advice on winch mounts would be much appreciated
Thanks Andy
W reg jimny, 31" trekker on 15x8 mods, ora 4.5 lift, poly bushed, pro-comp shocks, braided brake lines, sj 410 transfer box with 6.5.1 tg gears, KAP stainless exhaust, custom snorkel and extended arches!
Rodden87
Re: Hello again, grand vitara suspension help?
Post by Rodden87 » Sun Feb 08, 2015 9:42 pm
Nobody
Post by Anton » Sun Feb 08, 2015 11:01 pm
:welcome2: back! I know nothing about GV's, but someone should be along soon, there are a few GV owners on here. It's just that most of us have SJ's or Vitaras, a few Jimny's, but not as many GV's.
Post by ScottieJ » Sun Feb 08, 2015 11:04 pm
You'll need to do quite a bit of work to fit tyres that size on a GV, there's not many lift kits available for them really I don't think, plenty of places selling bodge lift parts like spring spacers etc though.
You will need to do quite a bit of trimming.
Tbh there's only a few people with modded GVs on here so you might need to wait a little while for them to pop on and reply.
Rodden87
Post by Rodden87 » Sun Feb 08, 2015 11:20 pm
Cheers chaps hope fully some one will shed some light if not I will just have to get angle grinder out after it get one lol
Rodden87
Post by Rodden87 » Sun Feb 08, 2015 11:37 pm
After a bit more of a look around It looks like a can get 3 inch suspension lift which give lots of arche height so the remaining problem will be arche width so it might be all down to how much you can trim?
Post by ScottieJ » Mon Feb 09, 2015 1:02 am
Where is the kit from?
There is a lot of crap around in this country at the moment so be careful.
Rodden87
Post by Rodden87 » Mon Feb 09, 2015 9:50 am
Both bits4vits and jimnybits sell the kits or components to do the lift.
Post by dan_2k_uk » Mon Feb 09, 2015 12:33 pm
There is a bit of plastic you can loose.
Guess it would need diff drip brackets like the Vit does. At least the front diff's and shafts are a bit stronger than a normal Vit.
Post by ScottieJ » Mon Feb 09, 2015 12:35 pm
dan_2k_uk wrote:There is a bit of plastic you can loose.
Depends on the engine, the 1.6 and 2.0 still have alloy front diffs, however I think the shafts are a bit longer so they will be at slightly less of an angle with the same lift on a normal vit.
