leaf spring to coil spring convertion
Darby
Post by Darby » Fri Feb 27, 2015 11:11 am
What are peoples thoughts on going to coil springs from leaf and has anyone done it, if so is it a hard job to do?
NylonAdmiral
Re: leaf spring to coil spring convertion
Post by NylonAdmiral » Fri Feb 27, 2015 11:25 am
Are you planning to stay road legal or not?
Darby
Post by Darby » Fri Feb 27, 2015 12:08 pm
yes was planning on staying road legal so guessing I need to stay leaf springs?
NylonAdmiral
Post by NylonAdmiral » Fri Feb 27, 2015 12:12 pm
Well, this is quite a well debated topic but the general consensus seems to be that if you coil your SJ then you'd technically probably need to get it IVA'd in order to be road legal. This isn't something that seems to be worth the hassle to me personally but you might think differently.
To be honest though, it depends why you actually want to go coiled? There are lots of Zuks set up to accommodate a lot of flex which still run leaf spring configs.
Post by Jordi » Fri Feb 27, 2015 12:14 pm
Very hard job to do properly.
Can be done and kept legal but requires an IVA.
If you looking to get more comfort and flex quite a few of us have gone / are going YJ. Also a few mix and match setups done with Hilux and Navara springs.
All depends what your aiming for?
Darby
Post by Darby » Fri Feb 27, 2015 12:36 pm
ok thanks just seeing what people thoughts where on it, where just looking at options to be fair, looks like you can still get the height/ground clearance from leaf springs
Post by ScottieJ » Fri Feb 27, 2015 1:30 pm
Height and ground clearance.......You don't need one to get the other ;)
Bigger tyres are the only way to gain clearance under the diffs and there are other mods you can do to increase clearance underneath, raising the transfer box and raising the sills etc.
I run YJ springs all round spua on 33" tyres, with a raised Tbox and tucked sills, it stupidly low for an SJ on 33s yet it goes where a lot of taller vehicles do.
Darby
Post by Darby » Fri Feb 27, 2015 1:35 pm
ok thanks, going to sounds silly here but as its all new to me, what do you mean by YJ springs?
Post by ScottieJ » Fri Feb 27, 2015 1:45 pm
They are leaf springs off a J eep Wrangler YJ, you do need an adapter kit to fit them but they ride well and flex. only issue is you loose a lot of your approach angle if you are on smaller tyres so Running Sj rear springs up front and YJ/hilux springs rear can be a better option on smaller tyres.
Darby
Post by Darby » Fri Feb 27, 2015 5:42 pm
Ok thanks, right I understand abit more now! All been very helpful,need to do some thinking and then get on with it!
