03 16vgrand vitara 'flat spot'
Chelsea
Post by Chelsea » Sat Mar 07, 2015 6:41 pm
Hiya im having problems with my 2003 grand vitara it seems to have a flat spot or hesitation when accelerating particularly at lower speeds the engine seems to 'get stuck' (revs and acceleration) then lurches forwards. im running it on Shell Vpower and have put a full bottle of redex in it.
a friend has a fault reader which has identified;
0130- unknown fault code
C1022/ C1036 front wheel speed sensor
B1503 evaporation temp sensor malfunction
could these be the problem?
what is the evaporation temp sensor and any ideas on the unknown 0130,
can any one help?
many thanks
Re: 03 16vgrand vitara 'flat spot'
Post by Darrell » Sat Mar 07, 2015 7:29 pm
Welcome to the forum.
The C1022 and C1036 are fault codes from the ABS, Right front and left rear wheel speed sensors.
The B1503 is a fault code from the air conditioning.
The code 0130 I don't recognise, however if it had a P in front of it, it would be O2 sensor problem.
This is more likely to cause running problems.
I would see if you could get a second scan with a different unit to confirm the codes.
I can get these sections from the workshop manual if your handy with multimeter.
Just a question on which dash do you have, as these changed late 2003.
Later type (hard top only) pic.......
Grand Vitara Console.jpg (81.29 KiB) Viewed 6286 times
Chelsea
Post by Chelsea » Sun Mar 08, 2015 3:44 pm
Awesome, thank you for your help, I don't know if it had a Problem before, I think I'll see if I can get a second set of results and maybe get the pre cat sensor, it's the same as in the pic the updated dash.
Thank you :)
Post by Darrell » Sun Mar 08, 2015 4:59 pm
Few extracts ..........
GV Evaporator Temperature Sensor.jpg (228.89 KiB) Viewed 6262 times
GV HO2s-1 .jpg (391.41 KiB) Viewed 6262 times
GV wheel speed sensors.jpg (333.27 KiB) Viewed 6262 times
Chelsea
Post by Chelsea » Mon Mar 09, 2015 8:04 am
Brilliant thank you
Chelsea
Post by Chelsea » Wed Mar 11, 2015 6:01 pm
changed the lambda sensor and it looks like a 5 year old changed the battery with new clamps (that didnt fit) dont think his fisher price tools could tighten it up haha
problem seems to be sorted thanks for your help
