FUEL GAUGE AGAIN
basil
FUEL GAUGE AGAIN
Post by basil » Thu Mar 12, 2015 10:13 am
Thought i had cured the erratic gauge after alternator replaced but it all over the place sometimes very high at other times low and on the odd occasion reads correctly.......is there room for me to put my hand up and wiggle the connector on the tag without removing the tank ??????
just in case its a bad connection and a movement might correct it...perhaps a touch of WD40 ON the spade terminal....
thanks Jim
timwilks13
SCUK Website Padawan
Re: FUEL GAUGE AGAIN
Post by timwilks13 » Thu Mar 12, 2015 10:53 am
Dont think there is room to get your hand up round the tank, pretty sure they sit too close to the boot floor. Trying it i guess would be my advice, stick your hand up, if it fits, bonus, if it doesnt, 4 bolts, drop the tank! Or just take out 2 bolts, and loosen the other two, should tip far enough forwards to be accessible.
basil
Post by basil » Thu Mar 12, 2015 10:56 am
Will try that later.....damn cold here at the moment......wish Suzuki had put a removable panel in the floor
jim
timwilks13
Post by timwilks13 » Thu Mar 12, 2015 10:57 am
Could always put one in :brows:
Post by twiss » Thu Mar 12, 2015 10:59 am
Haha yeah its annoying having to fit your fingers in the gap between the tank and the body...
Easy if you take the fuel tank off but who can be bothered with that..
More scraped fingers it is
Post by Jordi » Thu Mar 12, 2015 11:26 am
Its four bolts.
I'd just drop the tank down. There should be ample pipe and cables for it to drop a few inches. Just need to disconnect the filler pipe.
Post by dan_2k_uk » Thu Mar 12, 2015 1:17 pm
I've seen an SJ where someone had put a hatch above the tank.
basil
Post by basil » Sun Mar 15, 2015 10:31 am
timwilks13 wrote:Could always put one in :brows:
Tempted to jigsaw a hole in the floor with tank in place but its far too dangerous
jim
Post by ScottieJ » Sun Mar 15, 2015 3:58 pm
Just drop the tank, it's so easy and doesn't take long.
This might help you http://www.auszookers.com/forum/viewtop ... =17&t=4140
Post by Anton » Sun Mar 15, 2015 9:35 pm
That's something I'll have to try when I have the time/energy. My fuel guage is all but useless, it only ever reads half full or empty. As far as my SJ is concerned, there's no other state the tank can be in.
