Been a bit of an idiot.
Luke preston
Post by Luke preston » Mon May 04, 2015 10:07 pm
Hi guys, I was I bit of in idiot today. Had my rear axle apart to replace the diff and wheel bearings and have reassembled the half shafts without the back plate for the drum. Tryed getting them back off again but as you can imagine it's imposble. Any way I can make the hole bigger in the backing plate or is it a case of cat them off and start again. It's an sj 413 1987
Also I've seen some wheel spacers on eBay. 55mm each side. Set of 4 for £160 are they advisable for off road use or are they just going to cause problems.
Thanks
Re: Been a bit of an idiot.
Post by dan_2k_uk » Mon May 04, 2015 10:32 pm
I wouldn't run a spacer that wide.
It is possible to get the bearings back off the rear shafts if you heat the retainer up enough.
Need a good press and some decent heat though.
Post by donkeychomp » Mon May 04, 2015 10:37 pm
That's a bit large for a spacer. I use 32mm on the LJ and 40mm on the Vitara.
Ladaman
Post by Ladaman » Mon May 04, 2015 10:56 pm
The wheel bearing fitted through the backplate on my Samurai.
If yours doesn't I'd open the hole up until they slip over the bearing. The bolts hold it as true as it needs to be, the bore is just clearance.
Post by Tramp » Mon May 04, 2015 11:03 pm
Same here, if you have the bearing retainer plate already on, the drum back plate slips over the top of the bearing - mine didn't at first, but then I had it blasted and painted, and now it does! So you should be ok,
Post by dan_2k_uk » Mon May 04, 2015 11:18 pm
Some don't. It depends on which type it is.
One type has a separate retaining plate and on the other the drum backplate is all that retains the bearing.
Post by Anton » Mon May 04, 2015 11:34 pm
You can buy two piece bearing retainers from muddyzook but I don't know if they'll work with drums. Pretty sure they're meant for rear disk conversions.
Boyes
Post by Boyes » Tue May 05, 2015 12:55 pm
They should work fine with drums, mine did well until my bearing, shaft and collar split... Split bearing retainer still in place though.
Post by ScottieJ » Tue May 05, 2015 1:22 pm
corrected
dan_2k_uk wrote:I wouldn't run wheel spacers
:lol: :lol:
Post by Anton » Tue May 05, 2015 3:02 pm
Why do you want to make your SJ 110mm wider?
