Engine Identification
Beardy89
Post by Beardy89 » Fri May 22, 2015 10:37 am
Can anyone help identify this engine please?
Re: Engine Identification
Post by twiss » Fri May 22, 2015 10:54 am
looks to me like a 1300 single point injection engine from a late 1993 or 1994 samurai
Can't tell the CC really though as the head and block look pretty much identical
Should have 1298cc stamped on the exhaust side of the engine near the gearbox
Beardy89
Post by Beardy89 » Fri May 22, 2015 11:08 am
twiss wrote:looks to me like a 1300 single point injection engine from a late 1993 or 1994 samurai
I am 99% sure its 1600 out of a Vit. Wasn't sure on the SPI.
Beardy89
Post by Beardy89 » Fri May 22, 2015 11:31 am
How can I tell if it is SPI or Carb?
I am new to Petrol engines all my knowledge is with the landrover 2.5 Diesels
Post by ScottieJ » Fri May 22, 2015 11:34 am
That's SPI
As twiss says it will have the capacity stamped on the side of the block.
Beardy89
Post by Beardy89 » Fri May 22, 2015 11:40 am
ScottieJ wrote:That's SPI
It has a really bad idle. revs between 500 - 2500rpm and then dies.
is this a common problem with SPIs? Where is the best place to start looking.
Can I and should I change to a SU Carb, or should I fix the SPI?
Post by ScottieJ » Fri May 22, 2015 12:23 pm
Could be something as simple as a vacuum leak, there's not a huge amount of electrics on the SPI. check all the vac pipes over and if they are ok it could be a sensor etc somewhere? tbh i'm not that clued up on the SPI system.
Beardy89
Post by Beardy89 » Fri May 22, 2015 12:28 pm
ScottieJ wrote:Could be something as simple as a vacuum leak, there's not a huge amount of electrics on the SPI. check all the vac pipes over and if they are ok it could be a sensor etc somewhere? tbh i'm not that clued up on the SPI system.
Will do, I've got a long weekend now, so after picking parts up from you Saturday Morning I intend to spend as much time as possible get her ready for some offroading!
Post by twiss » Fri May 22, 2015 1:05 pm
If its a 1.6 engine fitted with the SPI system from a 1.3 maybe that is the cause?
Would probably mean that it's not injecting the right amount of fuel but I am not sure
Not entirely sure either of the differences between the 1.6 SPI system and the 1.3 SPI system
What registration Letter is the Samurai? If its an M or N reg then it may have been an 1.3SPI to begin with
Beardy89
Post by Beardy89 » Fri May 22, 2015 2:19 pm
twiss wrote:If its a 1.6 engine fitted with the SPI system from a 1.3 maybe that is the cause?
Hi Twiss it is on an N plate
