What is this wire (back of heater controls SJ410)
Phillips321
Post by Phillips321 » Fri Apr 22, 2016 10:36 am
Hi guys,
This isn't my picture but i wanted to know what wire goes to the back of the heater controls as shown in this photo.
I can't see what it links up to on the front of the panel? It doesn't seem to do anything???
Thanks
Jazza
Re: What is this wire (back of heater controls SJ410)
Post by Jazza » Fri Apr 22, 2016 11:26 am
I think that is used to illuminate the icons on the front panel.
(someone one please correct me if I'm wrong)
If so, then the red wire need to be connect to a live that is only active once lights are turned on. The black wire just needs to be grounded.
Hope this helps!
PS: R/Y - Red With Yellow Tracker is the illumination wire, going by that diagram. This will be one of the wires on the back of the clock, if you need a place to piggyback from (you can use a power probe to double check) :thumbup:
Post by ScottieJ » Fri Apr 22, 2016 12:14 pm
yes it's for the bulb that lights the switch panel up.
