BROKEN KEYS
EricG
BROKEN KEYS
Post by EricG » Wed Apr 27, 2016 7:34 pm
Any thoughts, please, anyone, on how to get half a broken key out of the lock, or is it easier to buy new locks?
______________________________
Keep on keeping on -- with a Zook!
Due to the current economic climate, the light at the end of the tunnel has been switch off.
SlimGrim
Re: BROKEN KEYS
Post by SlimGrim » Wed Apr 27, 2016 7:36 pm
Is it turned and broken or just snapped when pushed straight in? If it's the latter a very strong magnet may be of use?
___________________
EricG
Re: BROKEN KEYS
Post by EricG » Wed Apr 27, 2016 7:41 pm
It had been cracked and slightly twisted for a while. Didn't realise it had broken off till I tried to get back in after going to the shops.
SlimGrim
Re: BROKEN KEYS
Post by SlimGrim » Wed Apr 27, 2016 7:42 pm
So the barrel is fully turned? :/
___________________
EricG
Re: BROKEN KEYS
Post by EricG » Wed Apr 27, 2016 7:44 pm
Not sure because I usually lock it by pushing the button down before shutting the door
palo123
Re: BROKEN KEYS
Post by palo123 » Wed Apr 27, 2016 10:56 pm
My brother has a similar problem on his Suzuki swift. We just took the barrel out and used a small piece of wire to put pressure on from the back side of the key. Then using another piece of wire we pushed and wiggled the barrel pins to move the key out the barrel. After about half an hour we managed to get the other half out.
However, this will only work if the key isn't turned!
