Sj with 1.6 8v bogs going up hill
Liam plumpton
Post by Liam plumpton » Wed May 25, 2016 12:28 pm
I have a sj 410 with a 1.6 8v carb engine. I've put on a new fuel filter and have a facet pump on it mounted next to the tank. I've also blanked off the old mechanical pump. Yet when I climb a hill as I get to the top its dieing out as soon as I press the clutch down it goes back to normal until I let the clutch out then it happens again. Once I pull over and wait 5 seconds it pulls away normal again until I meet another Hill. Any ideas?
Re: Sj with 1.6 8v bogs going up hill
Post by ScottieJ » Wed May 25, 2016 12:36 pm
What carb are you running? was it ok when you were running the original mechanical pump?
Liam plumpton
Post by Liam plumpton » Wed May 25, 2016 12:37 pm
Standard vitara carb
Liam plumpton
Post by Liam plumpton » Wed May 25, 2016 12:41 pm
No it done the same thing when running the mechanical pump so I put the electric one on then it drove fine until it's started to flood it's self so removed the mechanical pump
Post by ScottieJ » Wed May 25, 2016 12:48 pm
Sounds like it could be fuel starvation, maybe the float is sticking in the carb, to be honest the standard carbs are junk anyway, might be worth thinking about a carb swap.
Other than that you might need to strip the carb and give it a clean etc. they aren't the simplest of carbs to strip and clean though.
Liam plumpton
Post by Liam plumpton » Wed May 25, 2016 12:51 pm
I've heard people put the su carb on would this benefit? And how easy is it?
Post by ScottieJ » Wed May 25, 2016 12:54 pm
It's easy to do, best to buy a modified inlet manifold rather than an 'elbow' adapter though.
It will cost around £200 for an inlet and a carb though unless you can find a secondhand modded inlet.
http://forum.suzukiclubuk.co.uk/vi ... =13&t=2249
Liam plumpton
Post by Liam plumpton » Sat May 28, 2016 10:43 am
Any ideas where I could find this stuff to buy already modified?
Post by twiss » Mon May 30, 2016 8:54 am
Best to speak to Rockwatt (Richard Wattam) on fb if you can for a quick response
https://www.facebook.com/richard.wattam
