Idle issues!!!
Idle issues!!!
Hello all. I can't get my 1.3 samurai engine to hold idle. It also cuts out alot when I'm driving. Even with the idle control screw turned up it will still hurt and eventually cut out. Any ideas? Cheers.
- donkeychomp
Re: Idle issues!!!
Has it been standing for a while? I'd clean the carb myself and see if that fixes it.
Re: Idle issues!!!
I swapped out the filter and she ran better. But had tappers off. How is the best way to clean out a carb on one of these?? Cheers. Jack
Re: Idle issues!!!
By changing it to a Hyundai, Daihatsu or Subaru (straight swaps), a Webber (easy swap, quite pricey) or an SU conversion.Bigtinasoup wrote:I swapped out the filter and she ran better. But had tappers off. How is the best way to clean out a carb on one of these?? Cheers. Jack
Standard SJ carbs aren't worth wasting any time or money on!
Re: Idle issues!!!
What carbs would you suggest then? I'm a hilux man so this us all new. I just want her to run well.
Re: Idle issues!!!
Webber bolt on kits are a couple of hundred quid, or you can buy a HIF44 SU Carb and get your intake manifold mandated by Rockwatt (that's what I did, and most of us do). It's a well travelled path, lots of write-ups on it and plenty of advice on here.
Re: Idle issues!!!
check that the fuel stop solenoid on the carb is working at that none of the wires to it have broken
