Facet fuel pump location
dazerede
Post by dazerede » Sun Jun 26, 2016 4:53 pm
Going to fit a facet fuel pump where has everyone fitted there pump thanks
4” calmini lift kit :)
Re: Facet fuel pump location
Post by twiss » Sun Jun 26, 2016 8:08 pm
I have mine attached to the inside of the front wing and it works pretty good, but you are suppose to mount them close to the tank. Most people mount them where the factory fuel filter goes
Rhinoman
Post by Rhinoman » Mon Jun 27, 2016 7:31 pm
It shouldn't be more than around 12" higher than the bottom of the tank, its a 'pusher' not a 'puller'.
Post by twiss » Mon Jun 27, 2016 9:09 pm
Yeah haha I just put it there cos I was lazy... works alright unless you run out of fuel... then you have to suck on the hose to prime it lol
Post by Anton » Thu Jun 30, 2016 9:12 pm
twiss wrote: Most people mount them where the factory fuel filter goes
That's where mine lives, seems happy enough. Can be noisy mounted directly to the chassis rails though, I should probably mount it on a rubber mat with rubber washers. I won't, because I'm lazy, but I probably should.
