Page 1 of 3
Do I need this on the tow bar
Posted: Sat Jul 23, 2016 4:22 pm
by dazerede
Can't fit this on with my back box is it needed it bolts to the chassis rail and to the bottom of the tow bar thanks
Re: Do I need this on the tow bar
by dazerede
And no I'm not removing the tow bar if anyone says that lol
Posted: Sat Jul 23, 2016 4:55 pm
I would say so. Its a strengthening brace.
Posted: Sat Jul 23, 2016 6:02 pm
by SherwoodNash
Jordi wrote:I would say so. Its a strengthening brace.
I have the same tow bar as you, it was an original authorised Suzuki fitted part.
When I fitted my new fuel tank recently, I took off the tow bar and that brace for access. I thought about not installing that bit too, just for cleaner lines but thought better of it, so it went back.
Also, you should have a 'sleeve' for the long bolt that sits inside the chassis member hole fixing point. Mind you don't tilt it when putting bolt in as easy to fall inside the box section and rattle around forever!
Posted: Sat Jul 23, 2016 10:25 pm
by dazerede
Ah ok guys will have to modify the bracket then cheers
Posted: Sun Jul 24, 2016 9:12 am
by andyrew
My towbar is a similar design and doesnt have the brace. Some do
some dont. Id be more inclined to change the back box as that
looks like exhaust rattle mania.
Posted: Sun Jul 24, 2016 1:33 pm
by ROBBIE
I never had that bar on mine, never used it for towing only recovery. And yeah that looks well rattly
Posted: Sun Jul 24, 2016 3:37 pm
by SherwoodNash
ROBBIE wrote:I never used it for towing only recovery.
I do both! I added a S/S 4Tonne D shackle :D
http://www.ebay.co.uk/itm/310607674262
Posted: Mon Jul 25, 2016 10:19 am
Are those shackles actually tested and rated? Being only 12mm diameter I would not trust it for anything but a very light recovery. Considering rated 3.25T shackles usually have a 18+mm pin I highly doubt those can handle 4T. Personally I will only use tested and rated shackles with the correct markings for recovery, I have seen what can happen when recovery gear and points fail and it can be fatal.
Do they carry any of these markings?
https://www.prolyte.com/en/prolyte-camp ... g-shackles
http://www.electricwinchshop.co.uk/3-25 ... ackle.html
Posted: Mon Jul 25, 2016 10:53 am
by SherwoodNash
It pulled out a Isuzu double cab 1 tonne pick up from a pub car park ditch OK.
I've learned from all those (especially Oz) recovery vids on YT, and followed all the rules.
