Instrument gauge swap??
SlimGrim
Post by SlimGrim » Tue Oct 04, 2016 10:42 pm
Is it possible to swap my 88 samurai's instrument panel that has just fuel/temp on the right hand round guage for the one with a rev counter? Crap quality Images of the ones I mean below :)
___________________
Re: Instrument gauge swap??
Post by Darrell » Wed Oct 05, 2016 12:39 am
The top one looks like the 86-88 type and the bottom one 88 onwards. I believe the connections are the same but unsure about fitting in the dash. I believe the type which should be a swap for the non tacho is this. I assume the wire from the coil to the dash is fitted as standard ? Hopefully the lads can give better advice on swapping :thumbup:
Post by ScottieJ » Wed Oct 05, 2016 12:57 pm
can you post up a picture of the back of your instrument panel, I might have a spare one with a tacho that will fit.
Darrell there are two different sets of connectors used on the 413/samurai instrument panels, not sure if it's age related or the old jap/spanish thing but I have gone to swap some that looked identical on the front before but the connections didn't match on the back.
Post by andyrew » Wed Oct 05, 2016 1:53 pm
The speedo cable may also be different. The non rev counter jap sami i broke had the 90 degree screw on fitting on the rear of the speedo.
Post by twiss » Wed Oct 05, 2016 2:24 pm
My 93 spanish one has a screw on speedo cable with the 90* adapter.... the jap samurais here have push fit cables
SherwoodNash
Post by SherwoodNash » Wed Oct 05, 2016 3:23 pm
SlimGrim
Post by SlimGrim » Wed Oct 05, 2016 7:41 pm
Cheers guys! Will have it off tomorrow when I change my cam belt & will take photos of the back, if you have one that fits my connector Scottie that would be 10/10 bud!
___________________
Post by ScottieJ » Wed Oct 05, 2016 8:48 pm
This is my spare out of a Spanish 91 I think
Post by ROBBIE » Wed Oct 05, 2016 9:18 pm
ScottieJ wrote:Image
Same as the one in my Spanish 91 Sammie
Post by twiss » Fri Oct 07, 2016 12:19 am
Looks like mine too apart from i've got a green circuit "board"
