Changing to a 12V Coil (SJ410)
courior
Post by courior » Thu Nov 24, 2016 3:46 pm
Hi all,
Im thinking to either go with a NODIZ system or just upgrade the coil by itself to get a bit better spark (i guess i have the original coil). Now i know i can go with a 1.3 dizzy and prob will be solved but im just wondering about a theory i have to make sure i understand what ive got.
So as it is, i have the 9v coil with a ballast resistor which i think is there to protect the coil AND points in the dizzy. If i put in a 12v coil off another car or a sammy and move the ballast resistor AFTER the coil so the voltage drops to 9v as it goes into the dizzy and so only "protects" the points, will this work?
Cheers!
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
Re: Changing to a 12V Coil (SJ410)
Post by ScottieJ » Thu Nov 24, 2016 7:36 pm
Just fit a 1.3 coil and dizzy and loose the points....it's the logical thing to do. I'm not sure your idea will really work.
Post by twiss » Thu Nov 24, 2016 11:27 pm
The resistor lowers the voltage by being connected in parallel with the coil. In series I think it will just get hot.
Should go megajolt and EDIS isntead of NODIZ... £260 just for the NODIZ ECU, you might as well buy a microsquirt for that... they arent much more expensive
Post by ScottieJ » Fri Nov 25, 2016 9:58 am
I have to ask why would you want to spend that much money on an ignition system for an F10? :shock: i think you have lost the plot :lol: makes so much more sense to just fit a better engine
courior
Post by courior » Fri Nov 25, 2016 8:56 pm
better engine here is 700 euro plus as i need the sammy box....... if there was a better engine that would go with my box, even with an adapter, i would be v interested... but alas there isnt... upgraded ignition would be a supporting mod for boost at a later stage :)
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
Post by ScottieJ » Fri Nov 25, 2016 10:13 pm
But there is....f10d ;)
Rhinoman
Post by Rhinoman » Wed Nov 30, 2016 9:09 pm
twiss wrote:The resistor lowers the voltage by being connected in parallel with the coil. In series I think it will just get hot.
Surely its connected in series with the dizzy to drop the voltage to 9V, its then bypassed during starting to increase voltage to the coil.
Personally I'd go with the 413 setup to get rid of the points but in the old days I had a lot of success with a transistorised ignition and a high-output coil. Mostly we used Boyer Bransden unit but I also had good results from a Sparkrite and a Mobelec. The points last longer and you do get a better spark - additional power is debatable but the engines did run smoother.
Post by twiss » Thu Dec 01, 2016 12:10 pm
Yeah sorry that's what I meant lol... I was sleepy :P
