Wheel spacers hubcentric or not?
Espresso
Post by Espresso » Sun Dec 11, 2016 11:44 pm
Well now i'm confused.com,
Hubcentric seem to read to be the better as they say they dont cause any vibration, but i cant find any that would fit the '02 vitara (convertable)
A few of the bolt on types on the E**Y
Just looking for a bit of guidance which are better and what size would i need for the hub to fit.
regards
Espresso
Espresso
Re: Wheel spacers hubcentric or not?
Post by Espresso » Fri Dec 16, 2016 6:46 pm
Oh also pls do i have to get 4 or can i just do the 2 front wheels?
Post by donkeychomp » Fri Dec 16, 2016 8:52 pm
NO! You need 4!!
Espresso
Post by Espresso » Fri Dec 16, 2016 9:34 pm
pls dont shout! i never had a 4x4 before :tomato:
Post by donkeychomp » Fri Dec 16, 2016 10:50 pm
Why do you want wheel spacers? If you fit them your tyres will extrude from the wheel arches making it illegal, unless you add arch extensions (see my build thread). Best bet are solid billet ones, LA Supertrux make them for about £120 a set. Cheaper option are Greystone but are a bastard to fit!
Post by ROBBIE » Fri Dec 16, 2016 10:51 pm
Why are you going for spacers?
Post by Jordi » Fri Dec 16, 2016 11:44 pm
donkeychomp wrote:Why do you want wheel spacers? If you fit them your tyres will extrude from the wheel arches making it illegal, unless you add arch extensions (see my build thread). Best bet are solid billet ones, LA Supertrux make them for about £120 a set. Cheaper option are Greystone but are a bastard to fit!
I know loads of people have had no issue with the greystone spacers, BUT, i think the billet alloys ones i got from LA Supertrux are the dogs doo dahs!!!
Post by ScottieJ » Sat Dec 17, 2016 9:15 am
Suzukis arent hubcentric, they are lugcentric.
I also have to ask why do you want spacers, there's no real need for them on a Suzuki.
Espresso
Post by Espresso » Sat Dec 17, 2016 11:11 pm
It's because the tyres rub on the chassis at full lock, as the tyres are larger, only realised this after I drove it home there is enough space I think to use them without protruding from the arches many thanks for the replies.
Espresso
