Sj oil light
dan00001
Sj oil light
Post by dan00001 » Tue Jan 17, 2017 4:22 pm
Hi guys,
Haven't posted on here much for a while but have a small problem. My 1986 sj413 has been running fine bar burning a small amount of oil, but just today on my way home from work, the oil light has started coming on at idle/low revs but goes off under acceleration/higher revs.
Regularly check oil level and top up if needed so this is not the problem,
A quick google search tells me its low oil pressure due to oil pump/main bearings/oil switch or a number of other things. What's the process of finding and fixing the problem? And is it okay to drive to work and back tomorrow?
Thanks,
Dan.
Re: Sj oil light
Post by ScottieJ » Tue Jan 17, 2017 4:38 pm
I wouldn't drive it until the problem is sorted.......once that light is on damage is already being done.
first start with a new oil pressure sender......but if the light stays on while running shut it down fast.
tbh once you are at the point that you need to swap the oil pump you might as well do a bottom end rebuild.
I might have a good 1.3 coming up for sale very soon.
dan00001
Re: Sj oil light
Post by dan00001 » Tue Jan 17, 2017 5:21 pm
Thanks Scott,
So by the sounds of it, its a fairly big problem/job?
Dan.
dan00001
Re: Sj oil light
Post by dan00001 » Tue Jan 17, 2017 5:23 pm
Can you point me in the right direction for the oil pressure sender please?
dan00001
Re: Sj oil light
Post by dan00001 » Tue Jan 17, 2017 5:29 pm
There's an era oil pressure switch in stock at eurocarparts, 8 miles away, too risky to drive there in the sj?
zook123
Re: Sj oil light
Post by zook123 » Tue Jan 17, 2017 5:34 pm
It's above the oil filter on the G13bb if that's a similar setup to your sj?
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Re: Sj oil light
Post by twiss » Wed Jan 18, 2017 11:22 am
The oil light only switches on at something like 0.2kg/cm
If its flickering you've got issues (been there done that)
As scott says pump/rebuild or chuck a new engine in (ahem... 1.6) ;)
dan00001
Re: Sj oil light
Post by dan00001 » Wed Jan 18, 2017 4:11 pm
Well I have swapped cars, it only happened last night on way home from work so hopefully not cause damage? Fingers crossed...
I've picked up an oil pressure switch today so going to give that a try now.
dan00001
Re: Sj oil light
Post by dan00001 » Wed Jan 18, 2017 4:25 pm
Just stuck the new oil pressure switch in, started her up, after about 30 seconds the light stayed on so I shut her down, I guess she's FUBAR?
Any reason why you guys are reccomending a new engine? Anything wrong with just sticking a new oil pump on?
zook123
Re: Sj oil light
Post by zook123 » Wed Jan 18, 2017 4:30 pm
When did you last do an oil change?
