gear changing
gear changing
hi guys picked up jimny tonight and the gear change is really stiff and hard to get into gear is this a common problem and is there a fix please
thanks in advance
scot
thanks in advance
scot
Re: gear changing
If it selects gears nicely when it's not running, it may be the clutch dragging.
Re: gear changing
thanks for that it has had a new clutch fitted
Re: gear changing
When you say stiff, have you tried going from 1st, N, and then 2nd?
Mine does this, I think it's a Jimny trait!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Re: gear changing
It will be the linkage from the lever to the gearbox. Probably seized and in need of a service.
I would change the gearbox oil while you are at it.
And make sure the clutch cable is correctly adjusted.
Re: gear changing
It's not a trait......you just need to fix the issuezook123 wrote:When you say stiff, have you tried going from 1st, N, and then 2nd?
Re: gear changing
ScottieJ wrote:It's not a trait......you just need to fix the issuezook123 wrote:When you say stiff, have you tried going from 1st, N, and then 2nd?
haha, In the Jimny world it is, SJ's maybe not!
Re: gear changing
Yep mine isn't like itScottieJ wrote:It's not a trait......you just need to fix the issuezook123 wrote:When you say stiff, have you tried going from 1st, N, and then 2nd?
Re: gear changing
ok how do i know its adjusted properlyScottieJ wrote:It will be the linkage from the lever to the gearbox. Probably seized and in need of a service.
