gear changing
Posted: Tue Feb 21, 2017 11:02 pm
by scot the sniper
hi guys picked up jimny tonight and the gear change is really stiff and hard to get into gear is this a common problem and is there a fix please
thanks in advance
scot
Re: gear changing
Posted: Tue Feb 21, 2017 11:17 pm
by Darrell
If it selects gears nicely when it's not running, it may be the clutch dragging.
Re: gear changing
Posted: Tue Feb 21, 2017 11:49 pm
by scot the sniper
thanks for that it has had a new clutch fitted
Re: gear changing
Posted: Wed Feb 22, 2017 8:19 am
by zook123
When you say stiff, have you tried going from 1st, N, and then 2nd?
Mine does this, I think it's a Jimny trait!
Re: gear changing
Posted: Wed Feb 22, 2017 10:14 am
It will be the linkage from the lever to the gearbox. Probably seized and in need of a service.
I would change the gearbox oil while you are at it.
And make sure the clutch cable is correctly adjusted.
Re: gear changing
Posted: Wed Feb 22, 2017 10:15 am
zook123 wrote:When you say stiff, have you tried going from 1st, N, and then 2nd?
It's not a trait......you just need to fix the issue
Re: gear changing
Posted: Wed Feb 22, 2017 11:09 am
by zook123
ScottieJ wrote:zook123 wrote:When you say stiff, have you tried going from 1st, N, and then 2nd?
haha, In the Jimny world it is, SJ's maybe not!
Re: gear changing
Posted: Wed Feb 22, 2017 5:57 pm
The Jimnys I've driven have changed gear fine
Re: gear changing
Posted: Wed Feb 22, 2017 6:38 pm
by ROBBIE
Yep mine isn't like it
Re: gear changing
Posted: Wed Feb 22, 2017 8:37 pm
by scot the sniper
ScottieJ wrote:It will be the linkage from the lever to the gearbox. Probably seized and in need of a service.
ok how do i know its adjusted properly
