SJ noisy final drive
Posted: Sat Mar 18, 2017 8:47 am
Hi all, sorry been away from here, busy but the 85 SJ going good, generally.
(This is a 2wd road condition)
Have a noise - at low speeds: take foot off accelerator but leave clutch engaged (so engine is braking a bit) - sounds rough, a bit graunchy. Drop the clutch and freewheel, all is calm, noise gone.
I have a guess there is excess rotational play somewhere in the drivetrain, and the noise is a sort of rotational resonance between engine and back wheels. I should check diff play and UV joints first I think.-?-
I'm tempted to start at the back and work forward - back axle/diff is 410. How much rotational play on the input shaft, anyone know the right amount or an acceptable tolerance please?
I'm pretty sure the gearbox and T-case are good.
Ideas and advice appreciated as always.
