egr valve
samuria
egr valve
Post by samuria » Sun Apr 09, 2017 9:56 am
took this off.... and it was full of carbon build up.
what difference should it make to the running???
its a 93 jlx 16i.. :er:
zook123
Re: egr valve
Post by zook123 » Sun Apr 09, 2017 12:21 pm
Will make it choke! Clean it with some carb cleaner :)
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
samuria
Re: egr valve
Post by samuria » Sun Apr 09, 2017 12:32 pm
thanks, will give a good clean :thumbup:
Re: egr valve
Post by Darrell » Sun Apr 09, 2017 6:56 pm
Help keep some emissions down :thumbup:
samuria
Re: egr valve
Post by samuria » Mon Apr 10, 2017 5:57 pm
as said it passed the mot.. but the engine now idles very slow....
also i took it for a good run and when i got home look at the exhaust(which is new)
and the pipe is black on the inside :er:
how do i turn up the idle? and sort out the sooty pipe?
thanks :thumbup:
Rhinoman
Re: egr valve
Post by Rhinoman » Tue Apr 11, 2017 10:47 pm
EGR improves part throttle efficiency so your fuel economy and throttle response will suffer without it.
The idle is controlled by the ECU, you need to determine why its not fuelling correctly. Usual suspects are a bad O2 sensor or a cracked exhaust manifold, it could be a dozen other issues though, you need to download the FSM and start working through the diagnostic procedures. Did you blank off the passageways when you removed the EGR?
dirk02
Re: egr valve
Post by dirk02 » Wed Apr 12, 2017 4:43 am
New O2 sensor may help, update us.
samuria
Re: egr valve
Post by samuria » Wed Apr 12, 2017 6:47 am
has new o2 sensor.
i did not blank off the passageways when removing
the egr :er:
Re: egr valve
Post by Anton » Wed Apr 19, 2017 10:55 am
Rhinoman wrote:EGR improves part throttle efficiency so your fuel economy and throttle response will suffer without it.
I was under the impression that EGR lowered efficiency, and that it's real purpose was to introduce inert gasses into the combustion chamber, which lowers peak temperatures during detonation and therefore hampers the formation of NOx?
I know you know far FAR more about engine management than I ever will, is the EGR=lower efficiency but less NOx thing a wives tale then?
CommVit
Re: egr valve
Post by CommVit » Fri Jun 14, 2019 3:25 pm
I have heard that removing it makes more power and gives better throttle response/ efficiency? But I may be wrong!
-Harley Davidson sportster chopper
-Vitara Commercial 1.9td
