Suzuki Grand Vitara GV 16 2 Door Convertable
Hi Guys, I do not know if you can help me out on this. I have just bought a second hand Suzuki Grand Vitara GV 16 convertible and it has the Engine Check light on. My Mechanic tells me that the Oxygen Sensor is not working and that is why this sensor is on but the car has two sensors one at the back and one at the front. Unfortunately in Malta I did not find these sensors as they have to order and it takes too long. Can any one suggest where I can buy these sensors and have them shipped ? I need to be sure they fit my model though as then it would be a problem sending them back if it is the wrong part.
Re: Suzuki Grand Vitara GV 16 2 Door Convertable
I would try your VIN here and hopefully you will see the correct sensors for your year/model.
https://www.catalogs.ssg.asia/suzuki/?lang=en#
Have you had it scanned yet to find out the codes? The codes will tell you which sensor it is... it could even be a different one!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
